Jhughes7 Posted June 3, 2007 Author Report Posted June 3, 2007 I will DISAGREE with you!!!!! NOT all cubs are bad for low end power, Mines NOT lacking at all, and YES its drag ported. I would also like to see a 358 smoke my 421........ NOT gonna happen. The vids you speak of the cubs obviously didnt have the set up right. There are plenty here who have seen my little 421 run, and spank 535`s. I would recomend a good 421 cub set up to anyone, they get the power to the ground better than most I think he was more or less saying the 358 has bad lowend, And if your 421 spanks 535's then its more than reasonable to assume a 358 can beat a 421. But like you and he both said, setup is key. Quote
375hp banshees Posted June 3, 2007 Report Posted June 3, 2007 I will DISAGREE with you!!!!! NOT all cubs are bad for low end power, Mines NOT lacking at all, and YES its drag ported. I would also like to see a 358 smoke my 421........ NOT gonna happen. The vids you speak of the cubs obviously didnt have the set up right. There are plenty here who have seen my little 421 run, and spank 535`s. I would recomend a good 421 cub set up to anyone, they get the power to the ground better than most haven't seen yours go slow :biggrin: so can't vouch for your bottom end power ,but just went trail ridding w/ 91banshee & his ported cub had ALOT of lowend power Quote
