banshee rz350 Posted May 31, 2007 Report Posted May 31, 2007 woundering if anyone knows what full exhaust will fit,because of powervalves i heard some dont fit,anyone help me thanks Quote
Matt96shee Posted June 1, 2007 Report Posted June 1, 2007 pt high revs and stock pipes for sure....i think i heard rockets will fit too. woundering if anyone knows what full exhaust will fit,because of powervalves i heard some dont fit,anyone help me thanks Quote
Matt96shee Posted June 1, 2007 Report Posted June 1, 2007 btw, i just finished my RZ conversion up if you have any more questions too. Quote
banshee rz350 Posted June 1, 2007 Author Report Posted June 1, 2007 pt high revs and stock pipes for sure....i think i heard rockets will fit too. hey what do you have for pipes i have stock ones Quote
Matt96shee Posted June 2, 2007 Report Posted June 2, 2007 i have paul turner high revs.....yaxy would be able to tell you how stock pipes run on an rz, he did it for a while. Quote
cbn70 Posted June 4, 2007 Report Posted June 4, 2007 what are you using for carbs? I quess more specifically, if you are using Keihins, what needle are you running?? what about pilots and mains? Quote
Matt96shee Posted June 4, 2007 Report Posted June 4, 2007 me? i'm running a 2into1 from cascade with a 35mm pwk. i love it! it revs to the moon! at this point i don't see a need for two carbs. PLUS, my thumb likes it too!!! vf3 reeds too. what are you using for carbs? I quess more specifically, if you are using Keihins, what needle are you running?? what about pilots and mains? Quote
banshee rz350 Posted June 5, 2007 Author Report Posted June 5, 2007 me? i'm running a 2into1 from cascade with a 35mm pwk. i love it! it revs to the moon! at this point i don't see a need for two carbs. PLUS, my thumb likes it too!!! vf3 reeds too. the stock carbs running 230 main,what you mean by 2in1 carb is it run better,iam from moncton new bruniswick,canada Quote
Yaxy Posted June 6, 2007 Report Posted June 6, 2007 Stock, PTR's and Rockets are the only pipes at this time that will fit the RZ conversion without inflicting dents. If you have time there is a new pipe coming that will clear and works great. Chris Quote
