Raoul Posted May 27, 2007 Report Posted May 27, 2007 I'm replacing the rubber cylinder seals on my Banshee. Where do you get that sealer that the clymer manual calls for? I can't even remember the name of the stuff. Supposed to put it on the seals when you install them on the cylinder head. Quote
ClimbAnyHill Posted May 28, 2007 Report Posted May 28, 2007 Are you talking about the orange RTV Gasket Maker? Quote
MDS2106 Posted May 28, 2007 Report Posted May 28, 2007 That shits called shallack or something like that.I just use the high temp red rtv and have never had any problems with leakage.. Mark Quote
375hp banshees Posted May 28, 2007 Report Posted May 28, 2007 That shits called shallack or something like that.I just use the high temp red rtv and have never had any problems with leakage..Mark just remember, put it on the seals b4 you install them, not on the cases, that way the excess is pushed out not in :thumbsup: Quote
Raoul Posted May 29, 2007 Author Report Posted May 29, 2007 just remember, put it on the seals b4 you install them, not on the cases, that way the excess is pushed out not in :thumbsup: Yeah, I used the Red Hi-Temp RTV silicone. Sounds good, I'm not going to worry about it then. Thanks Quote
