2002banshee05 Posted May 9, 2007 Report Posted May 9, 2007 hey i did sum work and cleaned my carbs and got everything back together and it wount start .. there is spark but i puled out the plugs and they are dry .. its not getting any gas . but theres gas in the carbs .. any ideas? Quote
JET 99 Posted May 9, 2007 Report Posted May 9, 2007 slides in correct? jets and needles in and seated correctly? do you actually have fuel in the bowls? did you have reeds and intakes out? both lines feeding carbs have gas? ?????????????? go back thru and check everything you did. have a buddy check (sometimes you miss it once check and miss it again).. if it ran before you cleaned carbs...... chances are you dont quite have something right!!!!!!!! just speaking from experience my.02 pennies :beer: Quote
Screaming Yellow Zonker Posted May 9, 2007 Report Posted May 9, 2007 Do you have the choke tube on? Did you have both the carbs apart at the same time? the bowls are different. How about fuel in the tank? Stupid question but sometimes you over look that. Please don't think I am calling you dumb because I'm not. Good luck. Quote
