LIM_Whiteboy4life Posted May 8, 2007 Report Posted May 8, 2007 Since this is the setup im going with im wondering since i have to go with a longer shock when i put the YFZ arms on since the stockers are way short. Will the Elka triple rates have more shock rod lenght than the OEM YFZ shocks with the huge extention on the bottom end..... just wondering.... Im going the the elka link setup in the rear. Should be around the end of June when i get the setup on and ready to rip. :beer: Quote
LIM_Whiteboy4life Posted May 8, 2007 Author Report Posted May 8, 2007 Or go the same route with YFZ works triple rates with a revalved/sprung rear shock...... cant deside just yet Quote
Washburn Posted May 8, 2007 Report Posted May 8, 2007 Or go the same route with YFZ works triple rates with a revalved/sprung rear shock...... cant deside just yet All you need from Elka is Dual rate the banshees shocks with the YFZ A-Arms arent long enough for tripple rate so that should save you a few bucks. Then when you look into +2+1 A-Arms all you really have to do to compensate is switch out the main springs witch is like 70 bucks. Works shocks are a little on the stiff side just to let you know. Last but cirtinaly not least the rear Elka with linkage is worth the extra money over a reworked stocker plus its weight in gold. This is all from personal expirence. If you have the extra $$$ go for it and get the best mod your Banshee will ever get!!! Quote
