Does anybody know where to find some good rz350/ ypvs cylinders. And what do you do exactly to convert your banshee into an rz banshee. All i know is that there is a lot of elictrical problems.
hey man, do a search on RZ350 and go to the beginning of the threads (about 6-8 pages) and read up....there's a few threads with electrical diagrams.
there aren't any "problems"...an RZ takes a few more electronic parts than a normal banshee is all. you can buy a harness on ebay and cut it down to what you need or use the diagrams i mentioned and do it your self.
what you need: powervalve(pv) servo, pv controller, RZ cdi, RZ regulator, RZ stator, RZ flywheel. then you need to find a place to mount it all. i mounted the servo to the TORS box mount and made plate to mount everything else to up front. you'll also need some pipes to clear the power valves on the jugs and some banshee style flanges for you pipes to go to. an RZ uses bolt on pipes where the 'shee uses a slip on end. my pipes are PT high revs. i think rockets work and stock 'shee pipes work too. try to keep your electronics from the same year...an '84 cdi and '84 stator or '85 and '85. you can mix and match and there's a website that tells you how to do it but you are looking at a slightly bigger headache. google "rz350 electronics", the page title is ELECTRICS. you'll have the ability to run a battery with no mods to the stator, i chose a battery eliminator since i bought a complete harness with it already there.
any questions just let me know.
matt
