where is everyone drilling cylinder for the fuel pump bung they say to put on right side just past reed cage just looking for some input thanks
We have done it that way, but we now have it in the reed valve spacer and that's the way we prefer it.
on the motor side of the reeds is where ive seen most of them ran.. between the cylinders is hard to get to on the mono blocks but is clean on the stock cylinders.. with the dm's i would put it right where you did.. just make sure that when you put the barb fitting in its not so deep as to hit the reed cage.. also teflon the threads so you dont have an air leak..
I have gone below the intake tunnels a couple times. The crank chamber is the best place to have the bung installed.
If anyone is interested I can make some bung jokes.................... :blink:
I have gone below to have the bung installed.
on with the jokes man!!..lmao
hell got it together last night and bolted down went to cycle crank and dont you know its got to come apart again because with the cylinder bolted down the crank is hitting the cases so have to have it machined some more
