raptorooster Posted May 3, 2007 Report Posted May 3, 2007 Hey guys, I have decided to sell my Banshee, I have a child coming and my county just outlawed ATV's!! It is as follows, only one half of a gallon ran since complete rebuild and new crank! -Hotrods 5mil longrod 4mil stroker crank -trail/play port and cases port matched to the cylinders -64.5mil 795 series Pro-lites -Pro-design cool head with .110 cut 20cc domes -RS 200 watt stator advanced 5 degrees with HP flywheel -Trinity 2 into 1 with Keihin 35pwk and K&N and outerware -Toomey radiator with billet pump impeller -Autometer water temp gauge -Dyna FS on curve 3 -F.A.S.T. Hd clutch and springs -+4 roundhouse swinger with billet dual row and DID X ring chain -new sprockets front and rear with case saver and upp chain slider -Alba procomp +2+1 control arms with works dual rates -EGT specialties avenger 3 EGT with fast reacting probes -FMF SST's with shorty silencers -Prodesign teather wired with factory kill switch still working -all unnessasary wiring stripped from harness -185 psi compression so this is a race fuel engine (could be changed to pump with new domes for $80) So the deal is, it is running a bit lean and from what I can find im at the biggest main jet available fron Keihin, So this will likely require going to a set of 33mil or 35mil carbs, this will cost about 500 bucks and is a piece of cake to do, otherwise short of needing new rear tires and some slow leaks in the front tires is pretty much set to rip. Pm me if you have any questions or call at 952-454-2691, im in Minnesota around St. Paul. Im fairly firm at 5 grand. Quote
5150banshee Posted May 3, 2007 Report Posted May 3, 2007 thro some pics up and did not see how much youe asking Quote
raptorooster Posted May 3, 2007 Author Report Posted May 3, 2007 I have some pictures on photobucket but cant figure out how to post them on here! Quote
