BRIAN BANSHEE Posted April 27, 2007 Report Posted April 27, 2007 hey guys was sup, hanevnt been on in a while caus ei havent had ne trouble, but NOW!!!, have ne of you guys ever had to replace the needle bearing in the clutch release lever? cause mine is FU*KED, i really dont want to have to pull my motor, but if i gotta i gotta i suppose Quote
MDS2106 Posted April 27, 2007 Report Posted April 27, 2007 (edited) When I changed the one on my son's banshee,I shoved a piece of a towel down the hole and cut the needle bearing using a dremmel, popped it out with a screwdriver then i used a little magnet to fish any metal shaving that fell on the rag.After installing the new one I ran it around for a little while and changed the trans. fluid....... Edited April 27, 2007 by MDS2106 Quote
BRIAN BANSHEE Posted April 27, 2007 Author Report Posted April 27, 2007 that would be fine and dandy, BUT i forgot to mention that i cant get the lever out of the god damn hole..........FU*KIN BIKE!!!!!!!!! Quote
MDS2106 Posted April 28, 2007 Report Posted April 28, 2007 The clutch actuator/arm should pop right out.Are you sure the rod is not welded to the clutch arm? Quote
locogato11283 Posted April 28, 2007 Report Posted April 28, 2007 yea something isnt right. the clutch arm should slide right out. you took off the bracket that holds it in right? its possible that the clutch rod wore a groove in the clutch arm causing it to not come out.. Quote
BRIAN BANSHEE Posted May 4, 2007 Author Report Posted May 4, 2007 I KNOW lol!!!! something is definatly FU*KED up, and no it isn't welded to the arm cause i had it out about six months ago, i believe the problem is that the bearing is totally messed cause there is a lot of grimey metal coming up through and i can feel in the arm itself that is all rough and pitted up, i now have the motor out of the bike does ne have ne ideas i dont really like the idea of a dremal tool cause i dont have that steady of a hand ??????????????????? Quote
