hey guys was sup, hanevnt been on in a while caus ei havent had ne trouble, but NOW!!!, have ne of you guys ever had to replace the needle bearing in the clutch release lever? cause mine is FU*KED, i really dont want to have to pull my motor, but if i gotta i gotta i suppose
When I changed the one on my son's banshee,I shoved a piece of a towel down the hole and cut the needle bearing using a dremmel, popped it out with a screwdriver then i used a little magnet to fish any metal shaving that fell on the rag.After installing the new one I ran it around for a little while and changed the trans. fluid.......
Edited by MDS2106
yea something isnt right. the clutch arm should slide right out. you took off the bracket that holds it in right? its possible that the clutch rod wore a groove in the clutch arm causing it to not come out..
I KNOW lol!!!! something is definatly FU*KED up, and no it isn't welded to the arm cause i had it out about six months ago, i believe the problem is that the bearing is totally messed cause there is a lot of grimey metal coming up through and i can feel in the arm itself that is all rough and pitted up, i now have the motor out of the bike does ne have ne ideas i dont really like the idea of a dremal tool cause i dont have that steady of a hand ???????????????????
