i had to break the seal on mine by prying them apart...i think there was a couple flat spots in the back to do it. it's not as easy to get them apart as you would think.
I cant get my cases apart. tried to use a rubber mallot but it did not break the seal.
Any idea on what else I can try
try to heat up the silver seal jizm then unscrew the bolts that hold the cases together all the way out then turn em in a couple times, then tap on them lightly and see if they split enough to pry them apart without gouging the shit out of them.
I got them apart... I had to keep going in circles around the cases with the rubber mallot and it finally gave in. Once they started to come apart I just pulled on them and they slid right off one another.
