I noticed that my trans oil is a little milky, like coolant has leaked into it. I am going to replace the seal and bearing on the impeller, and hopefully that takes care of it . I was wondering if anyone has ever had a problem with coolant leaking at the tube where the coolant enters the clutch cover?
I had the same problem with the o-ring leaking from where the tube comes from in between the reeds and goes into the case with the metal tube. I put some silicone around it just to see if it would work and it did.
