HardIzZlE Posted April 12, 2007 Report Posted April 12, 2007 im about to put on my e brake block off plate & i wanted to know if i should use loctite on the 2 bolts thx Quote
CadillacBanshee Posted April 12, 2007 Report Posted April 12, 2007 You can if you want. If you plan on taking it off to polish it or for any other reason DO NOT put loctite. Quote
FireHead Posted April 12, 2007 Report Posted April 12, 2007 Antiseize is probably more appropriate. Quote
Bansh-eman Posted April 12, 2007 Report Posted April 12, 2007 i just bolt mine on... theres really no issue if it comes loose or lets dirt behind it... there is a seal on that shaft... id just tighten it down but if you want to loctite it use blue so its not a bitch to get off... Quote
ClimbAnyHill Posted April 12, 2007 Report Posted April 12, 2007 I didn't use it my blockoff, never had a problem. Quote
seabass Posted April 12, 2007 Report Posted April 12, 2007 I didn't put lock tite on mine but I did put a thin layer of gasket sealer on it. It's never come loose. Quote
FireHead Posted April 12, 2007 Report Posted April 12, 2007 I didn't put lock tite on mine but I did put a thin layer of gasket sealer on it. It's never come loose. I think I may have put some anerobic gasket sealer on the last plate I put on. It's a good idea for sure. :thumbsup: Quote
HardIzZlE Posted April 12, 2007 Author Report Posted April 12, 2007 ok thx guys just wanted to make sure dident want something like dumb part to fall off sry for the double question but should i used loctite on the clutch & stator side bolts?? Quote
ClimbAnyHill Posted April 13, 2007 Report Posted April 13, 2007 ok thx guys just wanted to make sure dident want something like dumb part to fall off sry for the double question but should i used loctite on the clutch & stator side bolts?? I didn't use it on that stator cover either & running fine! I've checked those screws after a few weeks of hard trail riding and no prob there. Remember to replace those stator cover screws with allen head ones! Quote
