It was the reed petals.Thanks allot guys rock on shee HQ!! :biggrin:
I went through the same thing with my V3s. If you use a spacer behind the reed cage it will not push on the inner part of the reed cage just the outer. You need pressure on the inner part to hold the reed pedals in place or they move around and chip. Try holding the spacer up against the the back of the reed cage and you will see what i mean.
Edited by MFIC
Exactly what happened the outer pedals came out and were sitting in intake i run a 1/2'' spacer how do you fix this problem
damn where do i send my bill for the repair advice. lol
hope it works out for you.
lol,Wesw maybey I can pay it forward the next time you have a problem
Same exact thing happened to me with my v3's. I switched the spacer around and put my v2's in and havent had a problem since. I am waiting on my cascade stuffers and my new boss intake and the v3's will go back in.
loose the spacers. what intakes do you have, round openings or square on the reed side? If square get the square stuffers from cascade. The intakes i got from Jeff at FAST have round openings in them that match the opening on the V3s. Take your reed cage and hold it up your intakes as if it was bolted up and see if they match up and put pressure on the stuffer to hold the pedals in place.
Edited by MFIC
