fourwheelin24 Posted April 8, 2007 Report Posted April 8, 2007 which pipe is better for a modded engine, i have 4mm stroker 5mm longrod crank,ported cylinders,degrees key,2 into 1 carb, which pipe would be better, melton Quote
CenCalBanshee Posted April 8, 2007 Report Posted April 8, 2007 T-5s have more top end and 6s have more low I belive. So I would say T5s depending on what you are doing Quote
letsgetthisdone Posted April 8, 2007 Report Posted April 8, 2007 T5's are better on built motor's. If you ride mostly dunes, CPI's would work well too. If you're looking for bottom-end power some PT mids would be best. Quote
bansheeboy02 Posted April 8, 2007 Report Posted April 8, 2007 T5 T6 is for a mostly stock motor. Do not run t6's Quote
