Supergrandam Posted April 5, 2007 Report Posted April 5, 2007 Will putting a higher wattage stator do anything to increase the power of my banshee? Maybe better spark??? Thanks, Joe Quote
Bansh-eman Posted April 5, 2007 Report Posted April 5, 2007 no... only thing that will give you a stronger spark is a coil... cdi's and stators will not make your spark stronger... how every say your running a 100watt stator and your running 100 watts of lights then obviously your not going to have enough power to run both... but adding a higher output stator will not make your spark change Quote
Snopczynski Posted April 5, 2007 Report Posted April 5, 2007 Ricky claims his heavier magnet flywheels dont change spark intensity. However my motor guy says anytime you increase the size of a magnet, or its intensity if you will, in a a/c induced voltage setup it will increase spark intensity. I have one of the RS flywheels, I have not noticed a difference, but I guess it revolves around the laws of physics. Quote
