shee4speed Posted April 4, 2007 Report Posted April 4, 2007 Well I just ordered a RS timing plate and flywheel puller.Is there anything else I should need?Did a search; didn't help. Quote
badassbanshee479 Posted April 4, 2007 Report Posted April 4, 2007 you should be all set. Make sure to clean the threads in the flywheel real good before threading the puller in, and makes sure the puller bottoms out before you try pulling the flywheel. An impacket helps alot in the removal process also. Quote
