IROOST1 Posted April 2, 2007 Report Posted April 2, 2007 Used PJ 34 mm carbs. Ready to bolt on. Perfectly cleaned. New hoses. Cables included(not the best of shape but usable). These are are very clean. The specs are 152 mains, 58 pilots, 60 slide, GH needle on the 3rd clip. For use with gas. The intake id is 34.5mm, the intake od is 41mm, the airbox side is 58 od. The serial # on the carbs are 67RA1MF. Everything is in perfect working order. The one choke is stiffer than the other. But both are fully functional. These carbs i was going to use on my banshee but decided i want some 30mm or 28mm pwk's. I will trade these for those if anyone has them. Quote
yamaha04 Posted April 2, 2007 Report Posted April 2, 2007 when you say not the nbest of shape but usable do you mean the carbs or cabels? if you just mean the cabels my buddy toomeysheele has a brand new set of 28pwk's used them for like 3 rides then had some problems with his motor and has sent it away to jeff at fast to get some port work done so he was looking for some bigger carbs. honestly they are like brand new he also has them posted in the forsale forum Toomeysheele is his name Quote
IROOST1 Posted April 4, 2007 Author Report Posted April 4, 2007 when you say not the nbest of shape but usable do you mean the carbs or cabels? if you just mean the cabels my buddy toomeysheele has a brand new set of 28pwk's used them for like 3 rides then had some problems with his motor and has sent it away to jeff at fast to get some port work done so he was looking for some bigger carbs. honestly they are like brand new he also has them posted in the forsale forum Toomeysheele is his name yeah, the cables not the best. The carbs are near perfect except the one choke seems stiffer than the other. Does he have some pics and are the flat or d slides? Quote
