LiftdT4R Posted March 30, 2007 Report Posted March 30, 2007 Ok, so I finally got my frame stripped, cut and grinded, and I'm getting ready to gusset it. But, I went to gusset the steering hoop, and I know it's bent down. The paint is chipped and the IMS tank I had on there didn't clear the steering stem right. So, I guess I was wondering, when yall bend the hoop back, is there a measurement, or spot you should look at to stop bending it. Or is there a technique that works really good. I don't want to bend it too far or not far enough, because once it's gussetted it's staying. As always thanks, :beer: Jay Quote
FireHead Posted March 31, 2007 Report Posted March 31, 2007 Ok, so I finally got my frame stripped, cut and grinded, and I'm getting ready to gusset it. But, I went to gusset the steering hoop, and I know it's bent down. The paint is chipped and the IMS tank I had on there didn't clear the steering stem right. So, I guess I was wondering, when yall bend the hoop back, is there a measurement, or spot you should look at to stop bending it. Or is there a technique that works really good. I don't want to bend it too far or not far enough, because once it's gussetted it's staying. As always thanks, :beer: Jay PM BigRed350x. He actually has pictures of something like that. You can sort of see what I do to my frames in this picture. Quote
FasterThanU90 Posted March 31, 2007 Report Posted March 31, 2007 i used a fancy tool on mine called a porto power its practicaly a jack that u can use anywhere just fill in any needed space with 4x4s u might be able to get away with a car jack the straight up kind, bent mine till the tank fit right and the radiator shroud matched up Quote
