Ryda85 Posted March 30, 2007 Report Posted March 30, 2007 i just filled my rear master cylinder with dot3....now i see the manual says to use 4.......is this a problem? can i leave it or should i order some new fluid? Quote
Snopczynski Posted March 30, 2007 Report Posted March 30, 2007 i just filled my rear master cylinder with dot3....now i see the manual says to use 4.......is this a problem? can i leave it or should i order some new fluid? Dot 4 has a higher boiling point and its a silica based brake fluid. I would change it. Quote
jbooker82 Posted March 30, 2007 Report Posted March 30, 2007 Yep drain it and complety flush it out with DOT 4 fluid. Quote
Ryda85 Posted March 30, 2007 Author Report Posted March 30, 2007 ok ill drain and bleed it all out Quote
yfzdunejumper Posted March 30, 2007 Report Posted March 30, 2007 3 has never given me any problems when I have had to use it. But to be safe you shoud use 4. I wouldn't drain it if it was mine but I will advise you to Quote
