lowriderb Posted March 23, 2007 Report Posted March 23, 2007 heres a graph of The blaster.. so far on motor its ran (fastest time of a blaster that ive ever heard or seen) of a 4.61 backed up with a 4.57 (no spray) it has some issues to be worked out like the head gasket leaking, something leaking out of the cases (air leak), not enough weights on the clutches.. on the spray.. (i had to print it out and scan it, my printers almost out of ink so it came out pink..) Quote
lowriderb Posted March 24, 2007 Author Report Posted March 24, 2007 here's something to look at.. this is the lock up on the blaster.. this is NOT enough weights.. but here's what it did with these weights..the black line at the top is to shows the slippage of the clutches as it gets higher. motor.. nitrous.. theres deffinitly more to be had, with the motor to still be fixed much less being able to put the crank power to the trans.. Quote
MDS2106 Posted March 24, 2007 Report Posted March 24, 2007 Is that the little drag blaster from cp customs? Quote
lowriderb Posted March 25, 2007 Author Report Posted March 25, 2007 yup, that is the one.. its already been decided that the basket needs to be changed (this is the third or 4th basket its grooved to the point of no return).. also some other work is going to have to happen to fit another fiber in the clutch pack.. Quote
MDS2106 Posted March 25, 2007 Report Posted March 25, 2007 i have seen that little blaster in action at sicily island it definately kicks ass.... Quote
lowriderb Posted March 26, 2007 Author Report Posted March 26, 2007 i have seen that little blaster in action at sicily island it definately kicks ass.... what you saw at sicily island isnt anything... the spray set up was only used once (vids were posted a while back) and it wasnt doing anything.. now itll be on.. :biggrin: Quote
XR650 Posted March 28, 2007 Report Posted March 28, 2007 It always fairs well, keep it up, love to run against it XR Quote
SoCalinIt Posted March 28, 2007 Report Posted March 28, 2007 Those are some great numbers... Good post! Quote
lowriderb Posted March 28, 2007 Author Report Posted March 28, 2007 xr: the first couple of runs on the dyno were deffinitly less than impressive.. when you ran it last fall it may have only been putting down about 45hp/28tq, after about 30mins of tuning on the dyno it was pushed up to the 58hp/35tq.. then the spray was tuned in which when you ran it, it wasnt doing anything either.. socallinit: thanks.. once the motor is fixed from all the leaks i would imagine this little motor could hit up to 80hp on the spray..still with the same bore and stroke.. Quote
SoCalinIt Posted March 28, 2007 Report Posted March 28, 2007 socallinit: thanks.. once the motor is fixed from all the leaks i would imagine this little motor could hit up to 80hp on the spray..still with the same bore and stroke.. Dude... That is CRAZY! I bet it a blast to ride! Quote
lowriderb Posted March 28, 2007 Author Report Posted March 28, 2007 its deffinitly a fun ride.. it will carry the wheels at least half track on motor (before it was tuned in on the dyno) not just the power output but the weight of the whole bike is what makes it upsetting for many that have lined up with it..lol it weighs right at 135 without the bottle on it and right at 140 with it on.. heres a little more info on it and at the bottom there is a link to some vids of it.. http://cpcustoms.com/blasterdragchassis.htm Quote
SoCalinIt Posted March 28, 2007 Report Posted March 28, 2007 Man the vids for that Blaster are great! I bet the guy on the 450 was pissed! Quote
