macgillivary Posted March 13, 2007 Report Posted March 13, 2007 Do you need your voltage regulator to run or is it just for the lights? And whats the bare minimum wiring you need to run? I seen a wiring diagram and it looks like you ground the black wire from the stator, plug the connector from the stator to the cdi Then ground the main switch wire forget the color, ground the kill switch wire or do you leave it ungrounded? and run the orange wire to your coil and ground the other side of the coil this right? Somebody let me know Thanks Quote
Bansh-eman Posted March 13, 2007 Report Posted March 13, 2007 (edited) do a search , the topic was coverd no more then a week ago for the regulator... some good info was in the post for your harness... im assuming you arnt running lights? if not you pretty much got it in your post... Edited March 13, 2007 by Bansh-eman Quote
macgillivary Posted March 13, 2007 Author Report Posted March 13, 2007 ahhh thankyou so no regulator for me then lol who needs lights and I pretty much got the wiring or do have it lol? gotta install the tether though, need something to shut her off Quote
brugal Posted March 13, 2007 Report Posted March 13, 2007 You will need something to shut her off.You could always just take the wires off of the plugs to shut her off,then put them back when your ready to start her up. Quote
Bansh-eman Posted March 13, 2007 Report Posted March 13, 2007 your key if you have one will turn it off.. or splice in a tether... also you wouldnt need to pull the plugs... put in in gear and dump it, that will kill it too... if your not racing where your required a therth you can get a cr 250 killswitch use that... push style rather then a switch... of not same principles when wiring it in.... like said before do some searching... all of these topics have ben covered several time and many of them have diagrams and very good explanitions on how to do what your trying for... Quote
3 Posted March 13, 2007 Report Posted March 13, 2007 As you striping it down you can keep a good lenght of wire with the connectors and reused them while rebuilding the arness. Weld them on the arness. Yes it will mess up the color code but when you have striped one up you know what wire do what but the good thing is that you will have a arness that you can remove and leave all the component in place. My .02 cents Quote
Bansh-eman Posted March 14, 2007 Report Posted March 14, 2007 so do that but personally i dont see the point ... you can buy a harness off ebay for a fe bucks... why bother getting more wires going though a diagram and solder them back on... sees like it would cost just as much to buy one and alot less work.. just me though Quote
macgillivary Posted March 14, 2007 Author Report Posted March 14, 2007 hey thanks for the help guys got her wired up lastnight and sparking good Quote
3 Posted March 14, 2007 Report Posted March 14, 2007 so do that but personally i dont see the point ... you can buy a harness off ebay for a fe bucks... why bother getting more wires going though a diagram and solder them back on... sees like it would cost just as much to buy one and alot less work.. just me though I think you didnt understand or maybe its my bad english :biggrin: What i try to explain is, you strip the whole thing down, keep all the wires that you need and when you are at the point of cutting them down to the length you want you use one of the connector that you removed and weld it at the end of those wires. Then heatshrink it and tape it all up and thats done. Quote
3 Posted March 14, 2007 Report Posted March 14, 2007 One more thing, maybe that will make more sens, i moved up everything up front, CDI/regulator. Thats why i chopped down a lot of wires. Quote
Bansh-eman Posted March 15, 2007 Report Posted March 15, 2007 how did you relocated it? make sure you dont have the coil and cdi right next to each other... can cause interferance.. Quote
3 Posted March 15, 2007 Report Posted March 15, 2007 I buid a plate and bolt it on the tube that is right in front of the base of the radiator with U bolt. It is temporary until i repaint my frame, then i will weld a new plate on the same spot. Quote
Bansh-eman Posted March 16, 2007 Report Posted March 16, 2007 id fab a bar to mount it behind your rad not infront... depending on where you ride rocks could smack the cdi and cuase some issues... Quote
Snopczynski Posted March 17, 2007 Report Posted March 17, 2007 I think we have 4 bikes or so that all the electronics are relocated to up in front under the radiator area. We did it mostly because a few of them have subframes, and it looks a little cleaner without all the wiring in the back. Quote
3 Posted March 18, 2007 Report Posted March 18, 2007 i try to post pictures but doesnt work. I dont really worry about rocks because I made my own rad grill and I put a piece of grill behind the two big hole at the bottom of the rad. I ve my electrical cover. I will try later to post pic. Quote
