i posted up a thread about the optima 2 and i dont think im going to use it so ill take it back
check out the oils o this page and tell me which would be best to run
http://www.partscanada.ca/catalogue/2007/atv/en/index.html
i think the castor 927 is best
thanks
thanks
i use castor 927 because it smells good. I was advised by a few riders that have a ton of experience that castor is bad.... they say golden spectro is THE oil to use. It doesn't smell as good so i run the castor 927. Any oil will be good as long as your mixture is good with your current jetting. Just my opinion....
I have never run the 927 but hear it is a good oil. I run the Klotz supertechniplate...smells good and protects well. I am not sure if that is available through the website you linked cause I got sick of digging to find the oils.
