moved from MI to colorado and need to change the jetting and was looking
for a starting point. When it comes to jetting i hate it. The pistion i have are
vitos power pistions and bore is 20 over if any of that matters
THANK YOU FOR YOUR HELP
What was the jetting before you moved??? Use the same jetting, go down one size on the pilots, and down 2-3 sizes on the mains. You might have to drop the needle one clip as well.
The pilot sounds rich and the fuel screw being 2.5 turns out veryifies that....Try a 152 main, 45 pilot, needle 3rd clip and go from there....
