streakx Posted March 5, 2007 Report Posted March 5, 2007 I Have a bone stock 2006 banshee, the only mod i have is a UNI foam air filter, its around -5c outside, i got 240 mains, 27.5pilot,needle set on 3rd, i did a plug check & it seems lil too lean. ever heard of a bone stock banshee running on 250-260 mains??? Here's a picture(The quality sucks a lil bit): Thanks Chris Quote
okbeast Posted March 5, 2007 Report Posted March 5, 2007 To get an accurate reading while doing a plug chop you need to cut away the threads so you can look at the base of the porcelain. Looking at the top part doesn't really give you a good idea of where the jetting's at. Quote
dajogejr Posted March 6, 2007 Report Posted March 6, 2007 http://www.dfn.com/benkaren/plugchop.html Quote
Banchetta Posted March 6, 2007 Report Posted March 6, 2007 I read the ground strap and yes, they do look lean....It doesn't surprise me at those temps though....-5C is like 20 degreesF is my math is correct....You should be around a 240-250 main for around 50-80 degrees out. I'd be around a 260-270 for 20-40F.............This is at sea level as well... Quote
streakx Posted March 6, 2007 Author Report Posted March 6, 2007 I read the ground strap and yes, they do look lean....It doesn't surprise me at those temps though....-5C is like 20 degreesF is my math is correct....You should be around a 240-250 main for around 50-80 degrees out. I'd be around a 260-270 for 20-40F.............This is at sea level as well... Thanks for your advice, i'm waiting for some 250's & 260's right now. Thanks, Chris Quote
