sand rocket Posted March 1, 2007 Report Posted March 1, 2007 Cpi inframe pipes, 34mm mikuni carbs with pod filters, 18cc domes in the head, stock reeds and cages, and a dune port. I was pretty close with the stock carbs at 320 mains and 27.5 pilots, i couldnt get the neddle lean enough on the bottom clip. elevation is about 5000ft Quote
mpbanshee Posted March 3, 2007 Report Posted March 3, 2007 Depending on temp and elevation, 320 & 27.5 will probably be a good stating point. Quote
Banchetta Posted March 3, 2007 Report Posted March 3, 2007 I found on the pwk carbs that the bigger size carbs used almost the same jetting. Maybe one size larger for the larger carbs. You might have to get a different needle if the needle is maxxed out... Quote
