I need to know what I should jet my banshee at. I am from michigan and I an not sure what my sea level is and wanted to know If someone from michigan could chime in on this one. It usually gets around 30 degrees. I have LRD pipes, Stock carbs and I plan on getting the K&N filters. Anybody know what I should jet my carbs at?
i am in michigan....i have similar to your setup....k&n clamp on's and fmf pipes. i am running 300 MAINS and 30 PILOTS. i am a little rich i believe but it seems to run good all around... started and ran ok the other day at 22 outside
Thanks for the info. I think I will go out and buy a 300 main and 30 pilots because I have no clue whats in the carbs know. The guy I bought the bike from dint say what they were. Is there a way to tell what size they are?
when you pull out the jets it will or let me say should say the size on it, it's small and hard to read but should be there!
What type of K&N steup are you going to use? Lid on, lid off, clamp-ons?
