Gonna need to know your altitude before anybody will be able to help you much. :thumbsup:
50 pilot, dek mid or cel mid. 150 mains.
and shit can those fmf pipes.
got a quasi drag motor with low end pipes.
i have cel needle mid clip,150 mains,52 pilot,iam a little rich,but iam ok with that ,also iam at sea level,and i should be running a 50 pilot,or 48........ :banghead: :banghead: :banghead:
where are you rich at??
well when i rev all the way,ihave a little hesetation[sp]its from mid to top,and my plugs look good,i did a plug chop,and iam ok on my main,iam thinking i should play w my needle or pilot,iam also 2 1/4 turns on my air screw,so iam assuming its probably the pilot,iam no expert so any info greatly appriciated....... :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
i also have pjs 34,and a 421 cub
Mid to top won't be your pilot...but, if you need your air screw out that far, you could lean out your pilot size by one, no big deal if you don't.
Try the needle(s) wes suggested, then try different clips...
