Knight_Rider Posted January 26, 2007 Report Posted January 26, 2007 Anyone had problems getting the swing arm bolt out? ive spen the past 2 hours trying to free the bolt. Its seized inside the sleeve has anyone had to cut it before? Quote
Bansh-eman Posted January 26, 2007 Report Posted January 26, 2007 yea some people use a sawzall and cut it off... if you have never taken it out chances are its locked in there... Quote
HotCarl Posted January 26, 2007 Report Posted January 26, 2007 there are a ton of treads about this if you search it you'll find it is common problem. Heat, Bigger hammer, saw Quote
ohiobanshee Posted January 26, 2007 Report Posted January 26, 2007 The last one i did i used a air hammer and a impact. We hammered on the end while the impact turned the bolt. About 10 minutes and a half can of p b blaster it come out. :: Quote
Knight_Rider Posted January 26, 2007 Author Report Posted January 26, 2007 yea its in there good, ive had the impact gun on it while someone else was hitting the other end still not budging, i think its moved about an inch and its locked up again, what a stupid design i would have thought there would have been a greese nipple to stop this from happening grrrrrrrrrrrrrrrrrr Quote
okbeast Posted January 26, 2007 Report Posted January 26, 2007 If you've got an air chisel that might work, just watch out for the recoil :yelrotflmao: Quote
