hey guys,
the guy at the atv shop told me the best set up for my banshee with a K&N was to retain the stock cage and cut the foam off and cut the cage off. He said u then silicone the thing on (and bolt it in there) and a oval shaped K&N will fit great. He has a UMI racing kit but reckns it is round and doesnt fit the airbox as good as the standard adapter? is this the go for the set up?
thanks for the help
chris
hey guys,
thanks for the help
chris
Well, if you have to be cutting peices of your old filter off to fit your new filter, it dont sound like a good set up. The intake is to sensative to dirt, sand, or water getting in there and silicone is not the best glue. If you want to keep the airbox with or without the lid its best to go with the prodesign adapter and the oval k&N filter. If you can do without the box then the best setup would be the k&n independent filters. Shop around and check your options. Dont rig it, a small error could cost you alot. Remember to rejet.
hey guys,
thanks for the help
chris
Thats how the filter was set up on my bike when i bought it and It worked fine until i switched to pods.If you buy a the pro design plate your just paying for the name and a piece of alum.that does the same thing.
http://i16.tinypic.com/48n7dw9.jpg
thats what i use. proflow foam with hacked up airbox and a precharger.
the proflow is nice. you dont have too worry about ripping the filter to carb boots because of the extra weight and movement they see with just pods.
you can usually pic them up cheap on EBAY. i got mine for $10 because it looked like shit. little cleaning and it was good as new. bought 4 stainless allen bolts and nuts, drilled it out and and mounted it.
i wouldnt buy one new tho. way too much $
