which mod? you mean like a dyna cdi? they cost more then 100 bucks but yea i swear by my dyna! i couldnt be more happy with it... i guess i could if i wanted to spend the time and money going to a dyno and programming it but im not worrid about all that right now...
No, here check it out. CDI
Don't waste your money, they will not give you an extra 1000 RPM. Your intakes, carbs, porting, pipes and compression dictate how high your engine will run.
Get a timing plate for 35 bucks and advance it manually...or save up for a Dyna which can be programmed with a cable and software.
Boost bottle should get you that extra 1000 rpm :yelrotflmao:
yea the rev box crap... they use them on 4 strokes... like da said dont bother with it... im not even sure if it would make any differance on a 4 stroke casue the smae limitations apply for them.
