Hi - i have a 06 Shee and im having problems with the premix, could anyone tell me how many litres of petrol mixed with how much oil?
and is it wrong to re-fill the tank with the same premix before the tank is completely empty? :unsure: Thanks!
A good ratio mix is from 32:1 to 50:1. I would reccomend getting a mixing cup. It breaks it down for ratio mixing and by the gallons of fuel. No it does not make a difference to refill teh tank with the same kind of mixed fuel. If you were changing oils then I would recommend to do a flush in everything.
Im new to banshees so.. just bought one 3 days ago and i used 500ml of oil and the rest petrol my tank is 20 litres. i apreciate what you said but i dont get the whole ratio thing :s could you explain please ? is my mix of ''500ml of oil and rest petrol in a 20 litre tank'' correct?
Thx alot
Edited by 06Shee
if you have any doubts about the ratio mix get the ratio rite cup. it is your best friend when it comes to pre-mix. I used to be worred about the mixing until the guy at my local dealer showed me the ratio rite cup. They are only a few bucks and worth every penny.
here is a link for it at rmatv. http://www.rockymountainatv.com/productDet...mp;navType=type
Hope this helps
Hope this helps
You can also go buy one in publix or any grocery store or pharmacy or anything.You can buy one just about anywhere.
