Got my timing plate put on but it's diff. then the pro-design's or any others that I've seen that line up with the middle of the cases. Do you set it by the piece that has the pick-up coil on it that slides, and just line that up w/ what degree you want?
havent seen a trinity plate but moving the pickup is what needs to be done to change the timing.....so I would guess "just line that up w/ what degree you want"
