6speed
    04 blue
6speed's Achievements
  1. Well that sucks I found a set of hyper carbon fibers 4x156 fronts and 4X110 rears off a pred. for a real deal.....
  2. so the rears won't fit?
  3. super fast parts delivery and top notch service, even over the holiday's .....wish all mail order shops I've dealt with were this good....
  4. havent seen a trinity plate but moving the pickup is what needs to be done to change the timing.....so I would guess "just line that up w/ what degree you want"
  5. My buddies quad, we pulled the airbox and put pods on, @ 500ft above sea level , cold out right now 30-50 just depends on the day.......we put 240's in it first and he thought it was fallin off on top. The next step up that I had on hand were 270's, put them in and he says it's a little better but still not the top end he was hoping for. Personally I think it's as good as it's gonna get with stock pipes, I was thinkin we should drop back to the 240's and maybe raise the needle (it's at stock setting now). What do you guys think?
  6. I noticed that I have a tiny bit of play on the brake side of the axle only. The sprocket side doesn't have any. I dont guess I can just tighten up the axle nut just a hair instead of pulling everything apart for new bearings? Thanks inadvance guys.
  7. My bike still runs good , but after I've ridden it enough to get it warm and turn it off it rolls in gear on the slightest incline. I don't have a compression tester yet to look at numbers, but I'm guessin it needs rings. I'm sure this is a stupid question but on the first rebuild can I buy stock size rings and just lightly hone the cylinders and button it back up. Or do I need to bore it 10 over and buy pistons too?
  8. I'm gonna switch to engine ice and need to know how much to buy.
  9. title says it all
  10. Thanks everyone......I got the stuff I needed from F.A.S.T. , talked to Jeff......really helpfull and fast delivery........excellent service ......I highly recommend them to everyone.......
  11. Just installed the same set-up with a noss head yesterday. It's really amazing what bolt-ons will do for these things. The pipes fit perfect, look sweet and sound awsome. I would defintly recommend them.
  12. I couldn't really tell where it was leaking at , only that it spit quite a bit out. After a bit I found a little bit weeping out past a few of the studs so I RVT'd them. I got it out a little bit today and everything seems to have magicly sealed up over night. Guess time will tell. Thanks everyone
  13. Installed the head and T5s today. The bike runs good but it's blowing coolant from somewhere under load. With it just idling everything is good.
