edgehanger Posted December 29, 2006 Report Posted December 29, 2006 :verymad: I might sound like a rookie because i am. Heres what happen we went to the track tonight. Before we went to the track we tested the bike and the rear end would bounce or dip when we took off so we tred to strap it down so it would hook better instead of dipping. Heres where i got in trouble. We had it strapped in the back and when my buddy made a pass it dipped so the strap came unhooked so i told my boy to let some air out of the shock so it would sit lower. Bad idea. We figured it was a gas shock because the pressure left so fast and the back just drooped to the ground.We go try to put air in the shock and it did nothing and we couldn't make anymore passes. My question is are these gas filled shocks or did we tear something up? If they're gas filled how do i put gas back in?My buddy said to put struts all the way around but im thinking we would bend something if there is no cushion on the frame when we leave. Here are pics , should i strut it ? By the way these are marvin shaw shocks they look like hillshooters . I bought the bike from a sand dragger and im converting it to street. Quote
edgehanger Posted December 29, 2006 Author Report Posted December 29, 2006 i know somebody knows about these shocks come on guys. is it because im on asphalt i cant get help? j/k how do i put gas back in? Quote
odaen Posted December 29, 2006 Report Posted December 29, 2006 i know somebody knows about these shocks come on guys.is it because im on asphalt i cant get help? j/k how do i put gas back in? they are nitrogen filled.....I think they use nitrogen because it doesn't contain any moisture to corrode the internals it should be about 20 bucks or so to have them filled, but you'll definitely want to purge all of the compressed air out that you put in Quote
dawarriorman Posted December 29, 2006 Report Posted December 29, 2006 they are nitrogen filled.....I think they use nitrogen because it doesn't contain any moisture to corrode the internals it should be about 20 bucks or so to have them filled, but you'll definitely want to purge all of the compressed air out that you put in Yep. You can use compressed air if its filtered and the moisture removed (breathing air, like for scuba). Mostly nitrogen anyways. But you more than likely didn't get enough pressure in there. Quote
kb7kuh Posted December 30, 2006 Report Posted December 30, 2006 You can send them back to yarnell and they will refill them. My rear shock has 950psi in it. You will never ba able to do it unless you have the refill station that they sell, or rig up something with a big nitrogen bottle. Quote
racer Posted December 30, 2006 Report Posted December 30, 2006 they are nitrogen filled.....I think they use nitrogen because it doesn't contain any moisture to corrode the internals it also doesnt contract or expand in relation to temperature, thats why its great for tires. think superbike, thats all those guys will use. im sure many other pavement sports have gone the same way. Quote
dawarriorman Posted December 31, 2006 Report Posted December 31, 2006 it also doesnt contract or expand in relation to temperature, thats why its great for tires. think superbike, thats all those guys will use. im sure many other pavement sports have gone the same way. Yes it does. Have you forgotten the ideal gas law? PV=nRT EVERY gas expands and contracts in relation to temperature. Quote
