troy yamaha of ohio has some descent prices on full sets of new plastic....................
i think it was $369.00 for the regular blue and white sets
i know it was $469.00 for the limited edition black(cause i got a set)
$40.00 shipping.......(not to bad)
i cant wait to start putting all back together. motor is at jeffs and i got a pretty big goodies list with him
got some acerbis uniko handguards from rocky mount. atv.
debating on some other stuff for the shee
damn i think i got the sickness........................... :sick::sick::sick:
.020 cleanup bore, weld/true crank, bearings and seals, noss head 20cc domes,cyln. woods/play port,lower case port,pistons & rings,v-3s, intakes, 33 carbs, upp boots to air box, air-b adapter/k&n,shift shaft mod&spring,jeffs hd clutch setup,pipe clamps, trail light set,e-pull clutch handle,
i think thats pretty much it..... he has a running list that i seem to keep adding too........................
i forgot nology coil and wires and 200 watt stator and 4 deg on adj timing plate
Edited by JET 99
  • 2 weeks later...
Must be nice to have to $$$$ to do all that at once. Sounds like it wil be a fun ride when you get it back!! :thumbsup: :thumbsup:
alot of overtime and some double time on weekends adds up..................
my job is pretty cool, there is always some sh.. either wore out or somebody has loaded, set up, or pushed the wrong button at the wrong time.......
i do machine repair/weld at a place that runs work for catapiller and allison transmisssion plus some oil field work..........
med size lathes 30-120hp spindles
med size horiz. mach. centers 20-50hp spindles
med size vert. mach. center 15-30 hp spindles
a few manual knee mills,bridgeports,saws
i stay busy enough sometimes to busy..........
soo all work no play makes it easy to save the pennies!!!!!!!!!!!!!! :beer:
