coopershee Posted December 26, 2006 Report Posted December 26, 2006 Hey guys I have 2 35w trail tech lazer lights and I just bought 2 more and I was wondering what size stator I should run to power everything and also what kind of work am I getting myself into when putting the stator in?Im going riding on new years and I want to put it in before I go, thanks guys erick Quote
letsgetthisdone Posted December 26, 2006 Report Posted December 26, 2006 (edited) get a 200 watt ricky stator (www.rickystator.com) and you'll be good to go. I think you have to run regulators before the lights though, i'm not sure. I would just figure out a way to put to 75 watt lights on the bars though instead of having four lights it'll be way simpler with just two. four lights would be a lot of wiring and such :shoothead:. EDIT: The stator is pretty much a remove and reinstall job, just make sure to get the right puller for the flywheel. If u use a jaw type puller it will break the flywheel. Edited December 26, 2006 by letsgetthisdone Quote
CadillacBanshee Posted December 26, 2006 Report Posted December 26, 2006 The 200W is a good choice. Double check the plug set up before buying. Quote
