Hey guys im pretty new to this site im currently rebuilding my 99 banshee motor,i need help adjusting the shifter mechanisim which connects to the shift cluster for changing gear there is a procedure for doing it it states that the clearance must be equal. has anyone done this? any help would be appreciated
Jarrad
you should see a stud with a slot on it for a screwdriver with a jam nut at the base of it. loosen the jam nut and turn the stud while watching the distance from the shift star.
what is he watching the distance of the star for?that adjuster is to makeup the play beofre your clutch actuator disengauges your clutch...only thing that moves is the pressure plate....but that wont move by turning that screw...
Hi need help adjusting the shifter mechanisim which connects to the shift cluster for changing gear there is a procedure for doing it it states that the clearance must be equal. has anyone done this? any help would be appreciated
Jarrad
i don't think he wants to adjust the clutch. he wants to adjust the clearance between the shift arm and the pins on the shift star.
jarrad adjust the stud next to the shift star, not the one on the clutch. sorry if my terminology is confusing, i tend to drink :beer:
Edited by drunkbansheerider
The adjustment drunk is speaking of(which I think is what you are asking about) is eccentric. If you loosen the nut you can turn that stud (w/flat screwdriver slot in it) and see the shift shaft arm move up and down. Just get it as close to center as you can eyeball.
awsome cheers :)
