im looking to switch out the stocks to the 35mm pwk, for the best price. i found a pair on ebay with throttle cable and jets for $359. is there any were else i could get them cheaper, thanks for the help!
Call Jeff...he'll hook you up. Also...he sells taller cable adjusters and lighter springs so you don't get popeye forarms.
Don't forget...
with 35's you'll also need intakes and new air filters as well.... It's more than just carbs.
If you already have your TORS removed and got the cable, and it's in good shape....just reuse it.
The same cable works on PWKs as the stockers with the TORS removed...
