Billyboy Posted November 26, 2006 Report Posted November 26, 2006 Since i bought it new it has a weird off idle bog, Cant figure it out. I bought some K@N filters for it and removed the air box and rejetted it to the Dyna Jet specs for what i was doing. Have a 280 jet and whatever needles it came with on the middle clip and 2.5 turns out on the air screw. Still has the off idle bog but after the bog it goes fine. Im stumped!!! Quote
bansheeseat$$ Posted November 26, 2006 Report Posted November 26, 2006 Try turning your air screw in to were it is 1/2 turn out from closed and see if that helps.You will probably end up with it out 1 full turn from closed. Quote
Toomey Banshee Posted November 26, 2006 Report Posted November 26, 2006 Try turning your air screw in to were it is 1/2 turn out from closed and see if that helps.You will probably end up with it out 1 full turn from closed. Agreed, but if you cant get it cleared up with the air screws you might wanna bump up your pilots to 27.5's. Quote
Billyboy Posted November 28, 2006 Author Report Posted November 28, 2006 Agreed, but if you cant get it cleared up with the air screws you might wanna bump up your pilots to 27.5's. Ok thanks guys. I will try that. What about the timing? A buddy told me if i advance the timing it would also clear it up. What do you guys think? Thanks in advance. Quote
scooter Posted November 28, 2006 Report Posted November 28, 2006 what mods do you have? i have a 05 and had the same symptoms Quote
BlueBanshee05 Posted November 28, 2006 Report Posted November 28, 2006 Yea my 2005 did the same thng and all it turned out to be was a clogged pilot. I would maybe try that if u havent yet. Quote
