Well i was just wondering if you guy think those chrome clutch covers with the clear thing that shows the clutch or luck up is worth the 3 or 400 dollars, and isnt the luck up for higher up hp banshee, and how easy do the clear cover scratch up becasue i do trail, and does pictures
Generally speaking, if you're not drag racing a majority of the time, I wouldn't get one. The lock up is to keep your clutches from slipping on a high HP engine. If you do more duning or trail riding than racing, I wouldn't invest in a lockup/clutch cover, etc. Just my .02 :shrug:
but i thought you had to have your clutch cover drilled out and stuff to fit the clear on
They actually cut a portion fo the cover off and fix the billet aluminum housing onto the cover to clear the extra width of the clutch lockup. But like Big Blue said, you can run the aftermarket housing using a stock clutch if you want. They look nice and all, but sometimes you have to grind your right peg down slightly to clear it, and definitely have to jockey with the rear brake pedal.
what are some of the links
almost any builder offers them. some send them out to get done, others do them inhouse....just depends. I've taken a cover to Redline and picked it up the next day since he does them himself. His link is in my sig.
There are 2 styles that I've seen. Direct-Drive and Mattoon.
their websites are
http://www.directdrivecnc.net
http://www.mattoonmachine.com
Edited by odaen
