CenCalBanshee Posted November 4, 2006 Report Posted November 4, 2006 I just got this bike and rode it 2 times and the motor blew up i just want to make sure that my jetting is in the right place. Its at sea level mods toomey t5s uni pod filters right now it has 270 mains in it and i will be running 32:1 motul mix thanks for any help. not sure on what pilot is in there and i need to check what clip the needles are on just need to see what i should start off on to break in the motor right I had to also buy a crank so i want to make sure its right. The guy i bought it from just slapped some vitos cast pistons in and didnt even hone it to break the glaze on the cylinders. the pistons cracked around the wristpins and came apart and destroyed the center bearings on the crank. Quote
Handyman Posted November 4, 2006 Report Posted November 4, 2006 I just got this bike and rode it 2 times and the motor blew up i just want to make sure that my jetting is in the right place. Its at sea level mods toomey t5s uni pod filters right now it has 270 mains in it and i will be running 32:1 motul mix thanks for any help. not sure on what pilot is in there and i need to check what clip the needles are on just need to see what i should start off on to break in the motor right I had to also buy a crank so i want to make sure its right. The guy i bought it from just slapped some vitos cast pistons in and didnt even hone it to break the glaze on the cylinders. the pistons cracked around the wristpins and came apart and destroyed the center bearings on the crank. yeah you were running a little lean. I'm located in Hanford and I'm running 310/340 main, 27.5 pilot jet. My mods are in my sig and I run 32:1 as well. Sounds like the person you bought it from just got it running to sell not caring about the consequences. Quote
CenCalBanshee Posted November 4, 2006 Author Report Posted November 4, 2006 figured so ill up it to like 320s to start i think Quote
