quickbansheeman Posted October 30, 2006 Report Posted October 30, 2006 i have an 05 banshee with a few mods!! i installed t5's, v-vorce 3 reeds, boost bottle, 310 main jet, k&n filters and bored out to the next size and the air fuel mixture is turn once. i have a few problems with the bike. the gass comes out my carbs when i leave the gas open, also when i take of the bikes power band does not hit as hard. i even installed hotter spark plugs. my spark plugs a coming out black. when i hit six gear the bike sounds better. My friend beats me with a stock banshee. i cleaned out my carbs and put new spark plugs and its doing the same thing! i am new at carburators!!what should i do? Quote
fastbanshee8 Posted October 30, 2006 Report Posted October 30, 2006 It could be that your float height is set too high, or your needle and seat, above the float is dirty or ruined. Clean the needles and seats above the floats, and make sure the float height is right. Put everything back together, and if it still leaks, replace both needles and seats. Quote
quickbansheeman Posted October 30, 2006 Author Report Posted October 30, 2006 It could be that your float height is set too high, or your needle and seat, above the float is dirty or ruined. Clean the needles and seats above the floats, and make sure the float height is right. Put everything back together, and if it still leaks, replace both needles and seats. how would i adjust the float level? is that the only thing i would have to adjust? Quote
JustinC Posted November 4, 2006 Report Posted November 4, 2006 i have an 05 banshee with a few mods!! i installed t5's, v-vorce 3 reeds, boost bottle, 310 main jet, k&n filters and bored out to the next size and the air fuel mixture is turn once. i have a few problems with the bike. the gass comes out my carbs when i leave the gas open, also when i take of the bikes power band does not hit as hard. i even installed hotter spark plugs. my spark plugs a coming out black. when i hit six gear the bike sounds better. My friend beats me with a stock banshee. i cleaned out my carbs and put new spark plugs and its doing the same thing! i am new at carburators!!what should i do? You have a peice of dirt or something in your float needle and your running rich, give it a little air, then she will hit right, good luck Quote
quickbansheeman Posted November 4, 2006 Author Report Posted November 4, 2006 You have a peice of dirt or something in your float needle and your running rich, give it a little air, then she will hit right, good luck ill try that out tonight! thanx!!!!!!!!!!! :beer: Quote
