r2n2d Posted October 28, 2006 Report Posted October 28, 2006 I was testing my stator to see if it was my problem with my spark. I know on a stock stator it should be between 13.7 and 20.5. I have a 200w ricky and wanted to know if 27.4 was in the specs for a 200w Quote
kubiac3 Posted October 28, 2006 Report Posted October 28, 2006 Im not sure if the 200watt stator has different ohm ratings, you could call ricky stator and find out. But I just wanted to let you know that even if the stator tests good it can still be bad. I had a huge electrical problem couldnt find out what the hell it was replaced everything basically and stil nothing, replaced the stator that tested good and bam o, started on first kick. Quote
