I was testing my stator to see if it was my problem with my spark. I know on a stock stator it should be between 13.7 and 20.5. I have a 200w ricky and wanted to know if 27.4 was in the specs for a 200w
Im not sure if the 200watt stator has different ohm ratings, you could call ricky stator and find out. But I just wanted to let you know that even if the stator tests good it can still be bad. I had a huge electrical problem couldnt find out what the hell it was replaced everything basically and stil nothing, replaced the stator that tested good and bam o, started on first kick.
