georgeh3 Posted October 18, 2006 Report Posted October 18, 2006 I have a 97 banshee ,when I start it up, It starts on the first kick but, It revs at at about, 5000 RPM. I have checked the floats They are ok,The left side spits out a lot of unburned fuel from exaust. When I shut of the fuel The RPM's will slowly come down untill it runs out of gas. Any ideas ??? Quote
locogato11283 Posted October 18, 2006 Report Posted October 18, 2006 sounds like your slides are in the wrong way. have you recently had your carbs apart? choke tube is in place right? Quote
black sunshine Posted October 18, 2006 Report Posted October 18, 2006 Do you have any spark on that side? Quote
georgeh3 Posted October 18, 2006 Author Report Posted October 18, 2006 Is there a way to put the slides in wrong? I thought they only fit one way. I checked for spark on both sides and it was good ,but the left one is still white (both new 3weeks ago) Quote
csrmel Posted October 18, 2006 Report Posted October 18, 2006 you cant put the right slide in the right carb backwards. or the left slide in the left carb backwards, but you can accidently swap the ledt slide for the right, which would make them backwards because of the pin. do 97's have tors? because if they do and youre is connected it shouldnt let it rev like that. thats one of the beautifull things about tors. helps you save the engine from blowing up from user mistakes. Quote
georgeh3 Posted October 18, 2006 Author Report Posted October 18, 2006 Would having the slides in the wrong carbs cause the high reving? I have looked thru the air box and both slides are siting on the bottom of the carb. (no TORS) Quote
georgeh3 Posted October 20, 2006 Author Report Posted October 20, 2006 does anybody else have any idea's ? Quote
