Malfnet1 Posted October 12, 2006 Report Posted October 12, 2006 So I was wondering what you guys run for tire pressure when out on the dunes. I am going to be running stock front tires and GBC Sand Sharks and may switch over to my Haulers. I currently run the stock 4.4psi and was wondering what is good for sand. Quote
Bansh-eman Posted October 12, 2006 Report Posted October 12, 2006 So I was wondering what you guys run for tire pressure when out on the dunes. I am going to be running stock front tires and GBC Sand Sharks and may switch over to my Haulers. I currently run the stock 4.4psi and was wondering what is good for sand. anywhere from 4-8 psi Quote
Wallrat Posted October 15, 2006 Report Posted October 15, 2006 The general rule is you want at least 5 if you jump, then increase the pressure up to a max of 8 for wetter sand. Quote
headsup Posted October 18, 2006 Report Posted October 18, 2006 So I was wondering what you guys run for tire pressure when out on the dunes. I am going to be running stock front tires and GBC Sand Sharks and may switch over to my Haulers. I currently run the stock 4.4psi and was wondering what is good for sand. i run 3 psi on the back & 5 on the front for the dunes. Quote
