Hollister_Hitman Posted October 9, 2006 Report Posted October 9, 2006 I am installing the a 35mm single carb from trinity racing but I can't get the carb to fit into the airbox adapter. The hole in the carb is like the same size as the adapter. The adapter has an o-ring in it so I don't think I am supposed to use a boot. i didn't recieve a boot either. Anyone have this problem. Maybe my airbox adapter is for a different size carb? There was no mm size # on the packaging of the adapter. Quote
Flip73 Posted October 9, 2006 Report Posted October 9, 2006 When I put mine on it was pretty tight, at first I though it wasn't going to fit. Is it way off or really close - like close enough to work it on without damage? Quote
Hollister_Hitman Posted October 9, 2006 Author Report Posted October 9, 2006 When I put mine on it was pretty tight, at first I though it wasn't going to fit. Is it way off or really close - like close enough to work it on without damage? It looks close but neither hole has any flex. I am also going to call trinity to try to get some ideas, but any help here is well appreciated Quote
Flip73 Posted October 9, 2006 Report Posted October 9, 2006 ya know...now that I think about it more - I might have persuaded mine a little. I believe there were casting marks (or something or other) on either the carb or adapter - really small, but enough to cause it to bind and not fit together. I either filed it or wet sanded - but a VERY small amount - don't really remove any material, just clean up the edge. Also watch for any microscopic metal filings, probably don't want them in your carb. Quote
Hollister_Hitman Posted October 10, 2006 Author Report Posted October 10, 2006 ya know...now that I think about it more - I might have persuaded mine a little. I believe there were casting marks (or something or other) on either the carb or adapter - really small, but enough to cause it to bind and not fit together. I either filed it or wet sanded - but a VERY small amount - don't really remove any material, just clean up the edge. Also watch for any microscopic metal filings, probably don't want them in your carb. Thanks for your help. I called trinity and they said that I have to file down the hose clamp tabs. I got out the dremmel and it worked fine. Quote
Flip73 Posted October 10, 2006 Report Posted October 10, 2006 I'd love to but too much crap here in western MA! Quote
