Ron Burgandy Posted October 7, 2006 Report Posted October 7, 2006 I seached and couldnt find- anyone know? Quote
Big Blue Posted October 7, 2006 Report Posted October 7, 2006 As high as your pipes will let it rev. Quote
Ron Burgandy Posted October 7, 2006 Author Report Posted October 7, 2006 As high as your pipes will let it rev. So it depends? on what you got... -what about stock, whats redline on a bonestock shee?anyone? Quote
r/atvshee Posted October 7, 2006 Report Posted October 7, 2006 the way i look at it if your reving high and going slower than u should be going faster then its time to shift lol Quote
Ron Burgandy Posted October 7, 2006 Author Report Posted October 7, 2006 Im just curious to what it is....I heard it revs up to 16k?... Quote
Cotton eyed Joe Posted October 7, 2006 Report Posted October 7, 2006 Im just curious to what it is....I heard it revs up to 16k?... Just from what I remember its no where near 16k. I think a full on drag bike hits 10k-12k maybe. Stock is probably somewhere near 8k. If you had the dimensions of the stock pipe and a stock port map you could actually calculate it. Quote
STLBILL Posted October 7, 2006 Report Posted October 7, 2006 Suggest you search for "dyno" across all forums. That will give you a hint at what people are testing to. Here is a start: http://www.bansheehq.com/forums/index.php?...380&hl=dyno -Bill Quote
bigscary Posted October 7, 2006 Report Posted October 7, 2006 Suggest you search for "dyno" across all forums. That will give you a hint at what people are testing to. Here is a start: http://www.bansheehq.com/forums/index.php?...380&hl=dyno -Bill my drag bike doesn't make power past 10400......... but it is a large motor......I've seen 350's pull well past 11k Quote
rocketboy Posted October 7, 2006 Report Posted October 7, 2006 highly modifed banshees can hit 12k ...turbo banshees can reach over 13k a piped one might hit 9k and a stocker maybe 8k :beer: they have no rev limiter ,so it varies depending on what state of tune the motor is in . Quote
wildbansheeboy Posted October 8, 2006 Report Posted October 8, 2006 Rev it till it blows,Stock rev is around 9500 RPM Quote
rocketboy Posted October 8, 2006 Report Posted October 8, 2006 i respectfully disagree ....stock is not 9500 ,thsoe 25lb boat anchor pipes will barely rev past 8 grand Quote
Hollister_Hitman Posted October 8, 2006 Report Posted October 8, 2006 i respectfully disagree ....stock is not 9500 ,thsoe 25lb boat anchor pipes will barely rev past 8 grand Yeah I got those :: Quote
Ron Burgandy Posted October 8, 2006 Author Report Posted October 8, 2006 i respectfully disagree ....stock is not 9500 ,thsoe 25lb boat anchor pipes will barely rev past 8 grand so what do you think it is/ Quote
RILS Posted October 8, 2006 Report Posted October 8, 2006 so what do you think it is/ Red ine is when the peak power is made.As said eariler most well built machines dont see over 10500 and a stocker will be arond 8000. Quote
