r2n2d Posted October 7, 2006 Report Posted October 7, 2006 My bike has been acting weird lately. When I start her up she idles fine. Once I put it in 1st and let the clutch out it stalls out. I can rev it with the clutch pulled in but I am not sure whats going on. Any ideas???? Quote
Bansh-eman Posted October 7, 2006 Report Posted October 7, 2006 did you rebuild your clutch or make any adjustments to it? Quote
r2n2d Posted October 7, 2006 Author Report Posted October 7, 2006 I hadn't touched the clutch or anything. I had the tors electrical unplugged. I have keihn 28 pwks so there was no need for them. Quote
black sunshine Posted October 7, 2006 Report Posted October 7, 2006 My bike has been acting weird lately. When I start her up she idles fine. Once I put it in 1st and let the clutch out it stalls out. I can rev it with the clutch pulled in but I am not sure whats going on. Any ideas???? Try adjusting your air screws on your carbs. I still have stock mikunis but I recently messed with the air screws and ended up in the same boat you're in. Put the screws back to about 1 turn out vs 2 turns out and the bog went away. It was bad, like you say, let the clutch out and give it more than enough throttle and it would die. Rev up fine in neutral, though. Worth a try and it would be a real easy fix if it is the problem :shrug: Quote
